ONEX #54 Web Site
ONEX
P01
Torque heads
Removed the valves from the heads and cleaned the heads. After drying the head, reinstalled the valves.
Did final assembly of the case, pistons and cylinders.
Installed cool tins, push rod tubes and heads. Did final torque of the heads to 18 lb-ft.
Installed the small o-rings around the rocker shaft studs.
Assembly complete through page 22 of the assembly manual.
Heads installed
Remember to install cool tins
ONEX Home
1326
Basic Information
Certification
Finish and paint
Flight testing
Fuel
Systems
Trips
458
